FOUNDATION Fieldbus
Fieldbus install Disk2 Bad
I recently upgraded my windows 98 machine and needed to reinstall my NIFBUS Configurator (PCMCIA). The install started off just fine, but when the install process is installing from Disk 2, I get an error stating the file can't be read. After which the install fails. Is there anyway I can get a copy of the second install disk?
(7,196 Views)
Which version of NI-FBUS Configurator are you using?
Pelease contact "fieldbus.support@ni.com" for further help. And you need to send the serial number of your NI-FBUS Configurator software as well.
(7,196 Views)
