FOUNDATION Fieldbus
Hi Guys, I have a problem with Rosemount Radar Level Trasnmitter Model 5400 series with Foundation Fieldbus
Hi Guys, I have a problem with Rosemount Radar Level Trasnmitter Model 5400 series with Foundation Fieldbus, the indication of radar in NI-FBUS software configurator was good no Error, but when I try to connect the segment to the Centum VP DCS, the radar lost in the list, but another device in the segment still in the list, only the radar lost from the list.please your advice what make the radar lost in the list?, Thank you
(7,904 Views)
Hi Nanda,
Would you check if the addresses of the device conflicts with one of the new devices in the cascaded segments?
If this is not the issue, can you try to see what happens if you only use this one device with the same procedure you have done? Just wanna try to narrow down where the problem is. A capture by FBUS Monitor is even better.
Thanks.
(7,884 Views)
