FOUNDATION Fieldbus
How do I add NI-FBUS to my installer?
I am using an NI USB-8486 and NI-FBUS.  Everything is working fine and now I need to create an installation for the software to be distributed.  Under the "Additional Installers" page NI-FBUS is not listed anywhere.
My USB-8486 came with a DVD containing Communications Manager 4.1.1, Configurator 4.1.1, and Monitor 4.0.2.  I essentially want to run the installer that is on this DVD as part of my installer for the application I need to distribute.
How do I go about doing that?
P.S. I called and talked to an engineer who told me that NI-FBUS also requires NI-DAQmx Core Runtime.  Is that correct?
(8,712 Views)
Hi NHibgee,
It's intended that no NI-FBUS shows under "Additional Installer" page of Build Spec property. We do not support this because we didn't think this type of application is best suited for distribution/depoy.
If I understand you correctly, you second question is whether it'll work if you include NI-FBUS installer as part of the app installer you build. The answer is yes. And a user will have to install both NI-FBUS software (Communication Manager) and your installer for your app to work.
For your last question, I don't think NI-FBUS requires NI-DAQmx Core Runtime. Would you tell me on what platform are you running FBUS app?
(8,702 Views)
We sell flow control valves, some of which use FBUS to communicate.  This application is a tester for production to run tests on the valves before they are shipped.  It will be installed on a lot of computers at our facilities around the globe.  I believe everyone will be using Windows 7, but it is possible some may still have XP.  I can probably put it in the instructions to upgrade to Windows 7.
(8,693 Views)
