FOUNDATION Fieldbus
How to inspect the detail of NI-FBUS Configurator error
Now, I am developing an HSE device, and testing by NI Configurator.
Some parameter newly defined within HSE FBs has an longer length than H1's FMS limitation 246 byte.
The DD file looks being created successfully, because NI Configurator is showing the parameter as an collect length (1024).
Then, NIFCONF_ERR_DD_SIZE_MISMATCH - Actual data size dows not match the DD data size (-1000) is reported.
And the HSE packet is correct.
I have to inspect what error NI Configurator has actually detected.
Please can someone give some information how to inspect the detail of error in NI Configurator ?
(7,421 Views)
Hi Washiro,
Would you please give more detailed information about the parameters? I have 2 questions:
1. What are the types of the newly defined HSE FB parameters as you mentioned?
2. Which version of Fieldbus specification are these types of parameters defined in?
(7,382 Views)
