FOUNDATION Fieldbus
I am running windows 2000 on a Dell Optiplex computer. My difficulty are; 1) My device driver does not recognize the ATI-Fieldbus card. 2) My driver is not recognizing the device ID.
All installations must be done in the following order:
1) Install all software (setup.exe, drivers, etc...)
2) Power down the computer and plug-in the hardware and power the computer back up.
For more information on the ATI-Fieldbus installation, you can go to:
http://digital.ni.com/manuals.nsf/webAdvsearch/BA16E2F3D5D66C4186256B5F005B239B?OpenDocument&vid=niwc&node=132100_US
Let me know if you have any other questions. Thanks.
(8,281 Views)
Please start the kernel-mode driver by entering
"net start nifb"
at the command prompt. This method is especially helpful if you are unable to find nifb on the Show hidden devices list.
If you receive the message System error 31 has occurred, the cause is most likely an interrupt or memory address conflict. Set the device to poll mode or change the memory address value.
(8,281 Views)
