FOUNDATION Fieldbus
I cannot see methods that are in my DD Files.
I cannot see methods that are in my DD Files. The Methods tab shows up in the correct block but is totally blank. I run these methods on many other Foundation Fieldbus host systems but cannot see them in NI-FBUS Configurator. What could be causing this?
(7,202 Views)
Could you send your DD files with the CFF file to fieldbus.support@ni.com? We will investigate the problem.
Feilian (Vince) Shen
(7,189 Views)
I figured out how to impliment methods using Configuration Manager. You must select just the block you want to run the method from in te leftmost panel, then the methods will show up. If the entire device is selected the method tab will not appear.
(6,736 Views)
Thanks for your information. Method is defined in function blocks. Only function block dialog will show the method tab.
(6,694 Views)
