FOUNDATION Fieldbus
Methods don't work with NI Configurator v2.3.6?
When I execute a method using NI Configurator v2.3.6, I get the following error: Method interpreter runtime error. Error: Line 16: Argument #3: type mismatch. Method execution did not complete. Method execution has halted. What is causing this?
(7,925 Views)
What type of the devices are you using? Can you share the DD/CFF files?
The latest Configurator is 3.1 version, which supports off-line configuration, and it has some improvements on methods since 2.3.6 version. But not sure whether 3.1 version solves your problem.
(7,925 Views)
I'm using the Micro Motion Coriolis Mass Flowmeter. I can share the DD/CFF files if necessary.
Is upgrading to Configurator v3.1 a free upgrade? I just purchased Configurator this past December, why wasn't v3.0 or v3.1 shipped then?
(7,925 Views)
What is the method causing such failure? Is the method in Resource Block or in Transducer block?
I don't have the physical Mass Flowmeter device, but I have imported the DD/CFF files (revision 02) to Configurator 3.1 version. And it looks like the methods in resource block can work properly, but not sure about the methods in transducer block.
The 3.1 version is released this month, and it is not a free upgrade, you need to order 850283-01 to upgrade to this 3.1 version.
As I know, you should have 3.0 version if you purchased in last December, because the 3.0 version was released mid of last year.
I suggest you send your PO number and other purchase information to fieldbus.support@ni.com for NI support.
(7,925 Views)
