FOUNDATION Fieldbus
NI Configurator 15/16 does not see any devices.
I am running NI Configurator 16, I have both a Series 2 PCMCIA Card and a USB-8486.
Both of these connections always worked (not at the same time) Now for some reason it does not matter which interface I use, they do not see any devices, always Interface Idle. I tried changing the settings in the Interface Configuration Utility from FF Default, Old Default and even copied the settings from a PC which is able to connect using the exact same USB-8486. I uninstalled 16 and re-installed 15 and still the same. Something is wrong but I can't figure out what it is. Can I get some help please.
Message 1 of 1
(4,476 Views)
