 Markus Klein
			Markus Klein
			08-04-2011 04:08 AM
We want to use PCMCIA-FBUS Series 2 PC Cards in new Dell laptops with Windows 7 64 bit.
After installation of nifbsw401.exe and a reboot, I am inserting a NI-FBUS PC Card.
The FBUS card is not detected as NI PCMCIA-FBUS card, but as PCMCIA MTD-0002.
The driver for this card is then not found and I can't use the card.
The behaviour is identical with several of our NI PCMCIA-FBUS cards and with two identical Dell Laptops in every combination.
The cards are working fine on other laptops.
Is this problem known and are there any solutions known?
08-04-2011 10:52 PM
Hi, You said it can work in some other laptop. Are these laptops also installed with Windows 7 64 bit OS?
08-05-2011 02:34 AM
Yes, the cards are working fine on other laptops with Win 7 64 bit, also on other desktop machines with PCMCIA-PCI slots.
In the meantime, I found that PCMCIA MTD-0002 is a kind of default manufacturer id if there goes something wrong reading the card identification.
When I'm starting an emergency windows booting from CD based on Win 7 32 bit, I also get MTD-0002 as identification
My guess is now, that the NI-FBUS PC Cards are not compatible with the PCMCIA slot and/or the board chipset of this Dell Laptop.
Are there any experiences from other users with PCMCIA slots in Laptops that are not working with the NI-FBUS cards?
 LastOne
			LastOne
			08-05-2011 04:21 AM
What's the model, or service tag of your Dell laptop?
If possible, please try to find another PCMCIA card (not NI-FBUS PC card) to test if the PCMCIA slot and controller works well.
Here are some suggestions:
08-08-2011 04:44 AM
I upgraded the BIOS and the Chipset/PCMCIA drivers earlier without any improvement.
In the meantime I tested the PCMCIA slot with 4 other PCMCIA cards.
2 of them results in a blue screen, 2 others also have an unknown manufacturer id.
I will contact Dell support, this looks like a hardware problem of my Dell Latitude E5520.
Thanks for the hints.
 Tako Riet
			Tako Riet
			08-17-2011 03:07 AM
Hello Markus Klein,
Any news on this problem?
Tako
08-17-2011 03:17 AM
Dell changed the motherboard of the laptop and now PCMCIA cards are working, also NI-FBUS Series 2 cards.
Therefore this was not a problem of incompatibility or the NI-FBUS card but of the Laptop PCMCIA card slot itself.
We will need to have the board of the second identical laptop also changed.
This seems like a general problem from dell which is solved in the meantime, but I could not get more exact information about this.
Thanks for the useful hints to solve this problem.
