FOUNDATION Fieldbus
Stuck at"Initializing Board 0, Port 0 [USB]" with NI 8486
HI folks I'm trying to get the NI 8486 to communicate with the computer and I put
a sensor which couples the signal onto the bus to the NI 8486 unit.
I could see the Port 0 in Interface Utility but  whenever I run the Communication Manager I get stuck
on this "  Initializing Board 0, Port 0 [USB] ... " step...
I'm not getting much sensible response from NI's support so just want to check if anyone has some suggestions
on this situation?? I'd be grateful. Thanks
Message 1 of 8
(8,383 Views)
Could you please tell me the Software Environment you are using?
Like the version of the NI-FBUS software, which operating system.
If you need more detailed technical supports regarding the NI-FBUS products, you could always get to the support email addressof fieldbus.support@ni.com.
Thanks.
Chris
Message 2 of 8
(8,373 Views)
The interface Configuration Utility is 4.1  . So is the Configurator. So I suppose the Communication manager is also  4.1.
The evaluation version of NIFB Monitor is 4.0, although I don't think I'll need to use it.
Running on Win XP professional version 2002 service pack 3.
ps. I haven't been able to activate the Configurator yet. I keep getting error message when i try to activate on the NI website.
But for now I first need to get over this Communication Manager problem
Message 3 of 8
(8,371 Views)
Have you done this test yet?
1. Disconnect all the device off the USB-8486 first.
2. Have the USB-8486 connect to your PC.
3. Run CM to see whether any hang happens?
We will check whether the error is related to the device or not.
Thanks.
Message 4 of 8
(8,368 Views)
Yes. when i disconnect the sensor/ FB transmitter it does get through the 'initializing' step
but on the next step of "Configuring NIFB commu manager"  ,  a NI FBus process startup: fatal error
window pops up. but I guess I expect that since we're not connecting anything to the 8486 unit now.
So what do you suggest I do to get through to my sensor/ transmitter??
I downloaded the DD infos for it and imported the DD files but doesn't change anything. I think there must be
something else to be done..
Message 5 of 8
(8,358 Views)
I suppose I have replied you through the fieldbus.support@ni.com.
Please modify the default Address for the USB-8486 interface.
Do you have any updates?
Thanks.
Chris
Message 6 of 8
(8,344 Views)
I've changed it to 0x10 and it worked.   There's no problem with Communication Manager now.
Thank you
Message 7 of 8
(8,336 Views)
Great to hear that. Smiley Happy
Have fun with the NI-FBUS Software journey.
Chris
Message 8 of 8
(8,331 Views)
