FOUNDATION Fieldbus
Support of Field Diagnostic Alarms according FF-912 with NI-FBUS Configurator 3.2.3
I tried to monitor Field Diagnostic Alarms according FF-912 from  a FF H1 device with NI-FBUS Configurator 3.2.3 and the Alarm Monitor Utility.
Standard Block Alarms e.g. in case of a parameter change are monitored in the Alarm Monitor.
Field Diagnostic Alarms according FF-912 are not monitored.
Are Field Diagnostic Alarms according FF-912 supported by the NI-FBUS Configurator 3.2.3. or is something special to do to enable the monitoring.
If not, which tools or host systems are available to monitor such alarms ?
(7,179 Views)
Accepted by topic author VolkerG
Alarm Monitor in NI-FBUS software does not Field Diagnostic Alarms. You can try using NI-FBUS C API nifWaitAlert2 to monitor such alarm. The detail description of the API can be found in NI-FBUS Hardware and Software User Manual Chapter 6.
Feilian (Vince) Shen
(7,176 Views)
