FOUNDATION Fieldbus
USB-8486 disconnects at random times.
I am using a USB-8486 with a custom LabView program.  At random times in the execution, the 8486 uninstalls itself.  This is happening on two different computers and three different 8486's.  A software reset or a computer reboot doesn't fix it.  It worked right for quite a while, and now has begun to fail.  I'm using NI Communications Manager 4.1.1.  When the 8486 drops out, the CM says that the interface was removed.
(8,366 Views)
Accepted by topic author FOwens
Please upgrade your software. The latest version is NI-FBUS 15.0.You can download it here.
PS: If you use LabVIEW, please confirm the compatibility issue before upgrading.  NI-FBUS 15.0 could support LabVIEW 2012 to 2015.
Thanks!
(8,351 Views)
