FOUNDATION Fieldbus
Using FBUS Monitor with FBUS-HSE/H1
i want to use the FBUS Monitor SW with the FBUS-HSE/H1 (Ethernet) HW. But there is no interface to select. The NI FBUS Configurator works fine with the HW. I using the DHCP Server Tftpd32 v. 3.03. What can I do?
Thank you very much!
Harry Schäuble
(6,993 Views)
NI-FBUS Monitor should be used with NI-FBUS Interface device.
For example, if there is a HSE/H1 linking device, you can use Monitor to obtain H1 data on this device by connecting a cable between H1 port on HSE/H1 linking device and H1 port on NI-FBUS interface card. But for HSE, NI-FBUS Monitor does not support the detection and capture of HSE data.
Feilian (Vince) Shen
(6,987 Views)
