FOUNDATION Fieldbus
What is the default IP address of the HSE/H1 Linking Device?
I am evaluating an NI FBUS-HSE/H1 Linking Device. I am using a PC (not a DHCP server) to communicate to the FBUS-HSE/H1 but the PC cannot detect the device. When not assigned an IP address by a DHCP server, does the FBUS-HSE/H1 have a default IP address? If so, what is it? If not, is there a simple work-around?
Chris
Message 1 of 8
(9,829 Views)
Hi Chris,
I strongly suggest you setup a DHCP server between your PC and the HSE/H1 linking device, NI linking device can only obtain an IP address via DHCP server.
Another way is that you can find a DHCP capable software running in your PC, then your PC can function as DHCP server and assign a valid IP address to the linking device. I have ever used the "DHCP Server" of VicomSoft to work with NI HSE/H1 linking device properly, but this software is not free.
-- Sean Gao
Message 2 of 8
(9,814 Views)
Hi Chris,
-- Sean Gao
Message 3 of 8
(9,814 Views)
Thanks, your suggestion worked. I used a free-ware version of a DHCP client and successfully linked to the FBUS-HSE/H1.
My next step is to determine what software I need to control a Fieldbus network. Since I'm not actually installing a Fieldbus network, only setting up a system for the purpose of evaluating and demonstrating some Fieldbus components, I do not want to spend more than I have to on additional software. What minimal-cost options exist?
Chris
Message 4 of 8
(9,802 Views)
Hi Chris / Sean,
I assume that you mean you got a freebee DHCP "server" & not "client", as most PCs are clients.
Any chance you could direct me to the "freebee" as I have tried a few free ones for this problem but
have had no luck.
Currently I am using an old ADSL modem that has a DHCP server, but it means another box stuck
on the network.
I am also hoping that NI will allow future versions of the LD to boot with a "default" address as most
other LDs now do (something like 10.0.0.1-254 range would be nice).
Sean - is this on the wish list for a future S/W upgrade. Just about everyone that has tried to get
one of these LDs running has come up against this "non-standard" arrangement.
Allen
allen@fieldbus.org.au
Message 5 of 8
(9,798 Views)
Allen,
I used a free DHCP from http://perso.wanadoo.fr/philippe.jounin/tftpd32.html. Near the botttom of the page you will find the tftpd32.284.zip file. Let me know if it works. Another solution is to manually assign an IP address to the HSE/H1. I used the ARP command in Windows Command Prompt to assign an IP to the HSE/H1 and then used the PING command to verify the connection and connect to the device. Since I had already installed and set up the DHCP software, I cannot be completely sure which solution worked. It may have been a combination of the two.
Good Luck
Chris
Message 6 of 8
(9,782 Views)
Hi Allen,
I agree with you, we'd better provide a good solution for HSE/H1 LD customers to avoid such inconvenience. I have submitted this request to our future feature plans; however, it is a firmware project, which will not be included in the coming NI-FBUS 3.2 software.
Anyway, I will try to push it and work out some better solutions on this problem.
-- Sean
Message 7 of 8
(9,778 Views)
As of 12/27/06 it seems that NI has still not implemented a static IP address option for HSE/H1.  I would
think that some customers would demand this option, since an industrial Ethernet network is not
the same as a corporate IT network.
Our SMAR FF SYSCON has a static IP option.
The "solution" of using a 3rd party DHCP server package to assign the IP address is a sad commentary on the quality
of this product.  Could you imagine if customers had to download some freeware device driver to talk to a NI PXI rack ?
NI would be playing second fiddle to HP VEE if that were the case !
Message 8 of 8
(8,902 Views)
