FOUNDATION Fieldbus
activation process will not recognize s/n as correct
I have installed the software but when I try to retrieve the activation code, an error comes back that the serial number does not match the product. I have the serial number right on the certificate of ownership, and all of the information pre-populated so I don't know what is going on.
I really need to get this card working.... frustrating!
(7,519 Views)
The activation request is only for NI-FBUS Configurator. Please check which software your serial number belongs to on the certificate of ownership,
If the software is NI-FBUS COMM SW (Communications Manager), please ignore the activation request. NI-FBUS Communications Manager is free and does NOT need activation. It provides drivers for interface card (PCI-FBUS and PCMCIA-FBUS) and APIs for accessing FF network.
If the software is NI-FBUS CONFIGURATOR, please send your serial number to fieldbus.support@ni.com. We can help you check the activation problem.
NI-FBUS Configurator needs extra purchasing and activation. You can use evaluate version if you did not purchase Configurator. Configuator evaluate version only supports offline configuration.
Feilian (Vince) Shen
(7,515 Views)
