FOUNDATION Fieldbus
edit display error
I am using NI configurator 3.2.3 for Foundation Fieldbus application.
NI configurator has been running for a 5 days.  In transducer block window, when I open the menu to see the value of a parameter, a error window shows :" EDIT DISPLAY ERROR ERROR - 12: READING PARAMETERS FOR THIS BLOCK IN THE DEVICE DESCRIPTION.  PLEASE VERIFY THAT DD IS CORRECT FOR THIS DEVICE."
Does this window show up often after running for a long time?  Can anybody help me to interprete this message?
James
(6,459 Views)
Could you send the DD files to fieldbus.support@ni.com? I will try reproducing the problem and finding the root cause.
Feilian (Vince) Shen
(6,446 Views)
