FOUNDATION Fieldbus
field's foundation cable Conductor impedance & Conductor inductive resistance
(8,782 Views)
Hi Prakashsuyog,
I'm not sure the cable's parameters are usually the one that matters much instead of the power hub which has terminators, etc.
If you are looking at powerhub, please refer this spec.
(8,766 Views)
No it is about cable's conductor electrical parameters, i want specific value for conductor impedance & inductive reactance
(8,761 Views)
NI uses standard cables for FBUS connection.
The USB-8486 and PCI-FBUS/2 use a standard DB-9 male D-Sub connector to attach to the Fieldbus network. The PCMCIA-FBUS connects to the Fieldbus network using a cable that provides two connectors: DB-9 male D-Sub connector and COMBICON-style pluggable screw terminals.
So they are generic.
Reference: http://www.ni.com/datasheet/pdf/en/ds-379
(8,752 Views)
