Feedback on NI Community
Android: cannot delete larger sections
Typically I quote posts, but delete irrelevant sections. If I do that on Android, I can use the blue handles to select a portion of text and get a popup to cut, copy, etc.
If I select "cut" with a large section selected, only one character gets deleted. I expected the entire selection to disappear.
(Chrome, Android 7.0)
Message 1 of 9
(4,088 Views)
Hi Christian,
If you select the delete button, does the text disappear?
Is it possible to provide a video recording of this behavior?
Lili
Message 2 of 9
(4,069 Views)
No, the text remains. Here is a quick example (I press "cut" on the popup after selection of the text. I am not aware of a "delete" button.)
Note that all it does is delete the question mark, which was not even selected!
Message 3 of 9
(4,063 Views)
Thanks for the video. I'm unable to reproduce this on iOS, so it might be Android specific. We'll have to investigate this further.
Here is the button I was referring to:
Message 4 of 9
(4,055 Views)
Yes, the <x] delete button deletes the text, surprise! 😄 Somehow "cut" should do the same thing. 😄 (ctrl+x (=cut) does delete things on the PC)
Message 5 of 9
(4,051 Views)
On iOS, "cut" does remove all of the selected text, so I would expect the same functionality on Android as well.
Message 6 of 9
(4,049 Views)
This is still under investigation, but I wanted to note that this only seems to be occurring within the Chrome app on Android. In the Internet app, the cut option works as expected.
Message 7 of 9
(4,010 Views)
What is this? I am running 7.0 (nougat, pure, no vendor skin) and there is no "internet app", just chrome.
Message 8 of 9
(4,007 Views)
It must be a Samsung app.
Message 9 of 9
(4,004 Views)
