Feedback on NI Community
Announcing the NI Discussion Forums Upgrade
Laura, it's working today.  Thanks
Message 211 of 273
(5,769 Views)
The Macro dropdown is fixed (again).
Laura
Message 212 of 273
(5,750 Views)
Apologies if this has been reported before, but it is really bugging me and deserves a "bump" if it has.  When I have an unread discussion on the Idea Exchange and there are multiple pages of comments, no matter where I click I get sent to the very first comment.  When the new comment is number 31, it gets tedious to skip to the end.  Ironically, the problem is exacerbated by one of my favorite "improvements", putting the link to the next comment page on the bottom rather than the top.  Now I have to scroll to the bottom of the first page and then jump to the desired page.  I would appreciate at least being able to use the page number in the Unread discussions section.
Works as expected in the LV page.
Firefox on XP (not that I expect that to make a difference).
Message 213 of 273
(5,726 Views)
Darin, I usually don't run into that, because these days I use the unread discussions module on the right, where the linking does work correctly (but ONLY if you use the number in the New column Smiley Mad ).
I would say that:
  1. Clicking the number of new comments under the idea should work (and it actually does if the first unread comment is on the first page).
  2. The next and previous page links should be on the top as well.
  3. If you configure the boards to display the new posts when clicking the thread, this should work in the unread discussions module as well.
  4. There should be an easier way of getting to the unread module.
  5. Lithium should simply add a view similar to the rest of the forums, which will solve all these issues.
___________________
Try to take over the world!
Message 214 of 273
(5,711 Views)
Hi Darin - the case I have open about this is for the page numbers in the Unread Discussions module not jumping to the correct page.  I find that if I am in the full view of the unread discussions module (not just on the ideas main page) and I click on the number in the "new" column I jump to the first unread comment.  However, we definitely want the page numbers to work so I'll check in on that again.
Laura
Message 215 of 273
(5,678 Views)
I see the kudo night mode in this thread again!!!
21563i4A9215ED8F20F41C
Message 216 of 273
(5,663 Views)
AS of this morning my profile page (click on my name page) shows "No Tags yet".
Along with that the recently kudoed most kudoed are all re-arannged.
Ben
Message 217 of 273
(5,650 Views)
I cannot see my "Messages I recently kudoed"  or "Messages kudoed" or anything else other than the number of posts.
Is everything lost??? Should we all start from the beginning?
21604i12EB11DB121D0D1E
Message 218 of 273
(5,646 Views)
Ben
Ben: I can confirm that I can see your tags (on your public profile), but on my own logged-in profile, I also see "No tags yet". This appears to be a problem with the authenticated profile page.
Message 219 of 273
(5,645 Views)
21606i1E3067D39D6CCF02
21608iA6FB1B184548216C
Message 220 of 273
(5,637 Views)
