Feedback on NI Community
Announcing the NI Discussion Forums Upgrade
Regarding the black Kudos issue - If you are seeing this, do you have a User Agent Switcher installed in your browser?  It would be under Tools > Add-ons in Firefox and Tools > Manage add-ons in IE8.
Laura
Message 231 of 273
(6,629 Views)
Laura
I see black Kudos in one place, my iPhone with Safari.
Message 232 of 273
(6,617 Views)
I don't see that add on with my XP SP3 PC with IE7.
Message 233 of 273
(6,608 Views)
A new update:
When using the insert/edit link button on the editor the cursor is placed in the URL box instead of the text box.
Message 234 of 273
(6,569 Views)
@Laura F. wrote:
A new update:
If the text was highligthed that'd be great, so i can hit ctrl+v directly without having to select all or delete.  Or if it was just blank that'd work too.
Tim Elsey
Certified LabVIEW Architect
Message 235 of 273
(6,565 Views)
@Laura F. wrote:
A new update:
I don't see this happening. The cursor remains in the "Link Text" box. Using Firefox 3.6.8.
Message 236 of 273
(6,533 Views)
@smercurio_fc wrote:
@Laura F. wrote:
A new update:
Also, does not work in Chrome. And like Tim points out, unless the stubbed "http://" is highlighted (or gone!), the initial location of the cursor is irrelevant since the stub must be highlighted before a CTRL+V is performed.
Message 237 of 273
(6,529 Views)
So when are we going to see the indent/outdent controls back in the editor?
I would still like to know what possessed Lithium to remove them.
Message 238 of 273
(6,505 Views)
Indent and outdent are sort of working on our test site, but it's so slight as to be almost useless so I haven't had them turned on.  I just learned that the editor is a third party product so Lithium doesn't directly control it.  My last update about the buttons is that they will be investigated.  I also submitted the feedback that the link insertion box should have http:// highlighted.  I am also using FF 3.6.8 and see the cursor in the link insertion box, not the text box so I don't know what the difference might be.
Message 239 of 273
(6,483 Views)
While they're fixing the indent issue, tell them to also properly indent the rows in paragraphs which are in a list:
  1. The first line is OK,
    but the second line is aligned with the number, not with the text.
  2. A big part of having a numbered list is
    having that appearance.
  3. Also, do I need to point out
    that this used to work fine in the past?
  • Oh, and the same thing happens
    with bulleted lists.
___________________
Try to take over the world!
Message 240 of 273
(6,470 Views)
