06-18-2010 01:12 PM
Another bug:
This is most likely due to the agonizingly slow loading of the message editor. Is it just me, or is it actually slower than the previous one? If you click on the "Quote" button before the editor has loaded the toolbar you get to the "Unexpected Error Has Occurred" page.
06-18-2010 01:21 PM
@Laura F. wrote:
Hi smercurio-
I tried to reproduce this myself without any luck. Was there anything else you did - like preview? Were the threads in the same board or different? Was it the same thread? I believe you are using Firefox, correct?
No, I did not do a preview. The threads were in the same board: message 1 (in this thread) and message 2. The message in this thread was the one I had started composing, and then I decided to post message 2 in the other thread, hoping to consolidate the discussion in one place. Yes, I'm using Firefox. I'll see if another message comes up and I'll try it again.
06-18-2010 01:33 PM
I must be the only one that misses the dashboard. Is the a way to float the 'My Bookmarks to the top?
Why do some icon appear normal while others are distorted.
What's this Community!
And why dont the icons reflect that new messages are available. ie open folder icon
I dont like this new NI Discussion Forums page, its not very helpful. You now have to scan each board of interest whether any new messages.
regards
Ray Farmer
06-18-2010 02:41 PM
Perhaps there is a new and improved way to get to the same place, but I really missed the Advanced Search link that used to reside next to the search button. Now I do a blank search and then find the advanced search.
06-18-2010 02:43 PM
@Laura F. wrote:
- Tim - Unread Discussions for Idea Exchanges should be just below the "About" section so it's the second module. If you don't have anything unread, then it will not show up.
Any possibility of swapping the about and unread sections?
06-18-2010 04:05 PM
Ok, next batch of replies:
As I know more about the questions and bugs posted to this thread, I'll post an update.
Laura
06-18-2010 04:31 PM
Image insertion issue in IE has been reproduced and reported.
Thanks!
Laura
06-18-2010 04:53 PM
Having found the advanced search
, the search for my posts only seems to return a subset. This used to be a way to find the 'true' count, but that issue seems to be fixed.
I only post to about 4 boards and the search results seem to include posts from all of them. I have been posting for less than one year, and the earliest post returned seems to have the correct date.
06-18-2010 05:40 PM
The help pages have a huge section on blogs.
Maybe I am missing something, but I don't think that feature is enabled.
06-18-2010 07:46 PM
- Ravens Fan - I will check on the image insertion and report it
- Ray F. - uploaded avatars are stretched in IE8. It's a known issue that Lithium is working on fixing. On the home page, the boards with unread messages show up with bold text. I am checking on restoring the icons.
I was wondering about this because I saw your comment, but had not seen any issues with the icons even though I'm using IE8 at home. So a little experiment. I have compatibility view turned on. (Broken piece of paper icon next to the address bar has a bluish background) and the icons look fine. I turned off compatibility mode (broken piece of paper has a not so blue background and why did MS do something so stupid as to make the pressed and unpressed states look the same? It is a relatively small difference in blueness!!!!!
) and your icon looked stretched.
So try turning on compatibility mode.
Good news. I like the autosave. While typing this, the screen refreshed and my text disappeared. I saw the autosave link (it wasn't super obvious though), clicked it, and most of my message came back.
