Feedback on NI Community
Board level concepts like DMA,IRQ, BASEADDRESS
Please post the information of MAX, I Like to know the board level concepts like DMA,IRQ, BASEADDRESS. How this requirements are achieved using MAX.
1. If I m doing the configuration in MAX where my configuration of the DAQ Devices will be stored in the system?
2. What type of the file is it?
(4,704 Views)
Hello;
I didn't quite get your question, but when you are using PCI boards, the OS automatically selects all the resources that will be assigned to your board, and MAX only retrieves that information from the registry keys of the OS.
Regarding your other question, when you save a configuration file, you can double check which file max is using by checking the following registry key:
HKEY_LOCAL_MACHINE->Software->National Instruments->NI-DAQ->Current Version->Configuration Manager.
Hope this helps.
Filipe
(4,704 Views)
