Feedback on NI Community
Boarders went bad again
As seen here
the issue appeared resolved later that day but today....not so good again.  did you forget to carry over a fix -  That was a busy day.
At any rate could you fix it again please?
(5,090 Views)
Hi Jeff,
Are you still seeing the issue? I checked with a wide browser window and zooming in/out (which reproduced the issue previously), but I am not seeing the problem. Can you confirm that you're still seeing the problem and it wasn't just a momentary hiccup?
Thanks!
Matt
NI Community Team
(5,069 Views)
I'd say yes- I checked Zoom is default
The snips don't really show the problem well and apper to zoom- if fact the first snip is with the browser window all the way side to side on the monitor, the second was about 1/2 screen wide
(5,059 Views)
To amplify the problem I have a dual monitor set-up.  a laptop display at 1366x768-  I can extend the window across the whole screen and see the whole width of a post and read the content without scrolling.  HOWEVER I like to keep the Forums on the secondary monitor so I can get some work done. it is 1024x786  Impossible to read a thread
Window maximized 1024x786
(5,055 Views)
Hi Jeff,
What you're reporting in this topic is different from the issue you linked. In the previous issue, the page formatting changed (colors, text size, table borders, page width) at a certain browser width. What you are experiencing now isn't a bug, but is simply how the site behaves when your browser is below a certain width. The text doesn't wrap and you have to scroll horizontally to see text and other items on the page. This is discussed in the topic you linked to here and here. This, along with the text wrapping, will be addressed when the forums adopt a responsive design.
You could try changing the font size to small to see if that helps. You can do this in My Settings > Preferences > Display.
(5,050 Views)
Browser zoom 90% will have to do as a workaround then I guessSmiley Sad
(5,043 Views)
