Feedback on NI Community
CLF on VI Hierarchy
Anyone notice the new feature of LV2009?  Now you can see CLF on VI Hierarchy window.
Nice feature.  Now everyone can sneak peek what's behand NI's password protected VIs.
Is this a bug or what?  It should never worked for password protected VIs!  It enough works for diagram removed VIs!!!
George
George Zou
(7,319 Views)
You can post here
This is feedback regarding the forum
(7,300 Views)
(7,297 Views)
 I suppose clf
(7,295 Views)
Call library function :smileytongue:
(7,294 Views)
Are you serious??  😮
My trial version of LV2009 just ended, so I cannot check it out.
That's horrible if true..  😮
(7,280 Views)
I don't quite understand the issue. OK, so you can see the Call Library Function Node. It tells you the name of the DLL and the function being called. That's it. No parameter information, or what's actually wired to those parameters. How does that provide information on what the block diagram is actually doing?
(7,259 Views)
