Feedback on NI Community
Can we disallow attachments starting with "Untitled..."
As mentioned several times, many users are too lazy to even give a proper name to a VI before attaching here (example).
This means that if somebody attached "untitled 1.vi" this morning, and somebody else attaches a set of "main1.vi" and "untitled 1.vi" VI in the afternoon, "main 1" will open with the old "untitled 1.vi" because the new version got renamed by the browser to "untitled 1 (1).vi" causing the caller to break or misbehave, and causing confusion for everybody trying to help.
Some related posts are here (Reply AReply B), but there are many more.
(2,811 Views)
Hi Christian,
Thanks for the feedback. There isn't any functionality like this out-of-the-box. As a workaround, when encountering these types of filenames, you can right click > save as and rename it before saving the file locally.
Lili
(2,798 Views)
Renaming will not work directly, because the caller expects a certain file name for the subVI (case # 2 above). If I have to first start herding cats before being able to look at the code, the chance of providing help is greatly reduced.
No big deal, though. Maybe the posting guidelines could add a few sentences about file naming. Personally, I prefer zip files whenever there is more than one file.
(2,784 Views)
