Feedback on NI Community
Change in hyperlink in message threads?
@RavensFan
Do you have an example of this? Also, if I understand you correctly, Firefox delivers you directly to the message, but IE sends you to the interim message. Is that correct?
There have been some changes to the underlying move/archiving system, but I don't believe this changed so we will need to investigate.
Thank you,
Mark
Product Manager
Customer Learning, Community, Online Documentation, and Support
Message 11 of 14
(901 Views)
Hi RavensFan,
I was not able to reproduce it. We had an update today that may have fixed this issue. Can you please let me know if you are still seeing this behavior?
Best Regards,
Kristi Martinez
NI Community Support
Message 12 of 14
(895 Views)
That might be fixed now.  I saw a moved message today.  https://forums.ni.com/t5/LabVIEW/Como-puedo-mover-un-slide-con-el-movimiento-de-otro-slide/m-p/40660...  This time when I click on it, I do get the intermediate message like I'd expect.
Since it was last week when I most recently observed this, whichever messages I saw that caused me to repost this issue have now disappeared.
Since today's moved message seems to be working just fine, I can only assume that the update fixed it.
Thanks.  If I see it return, I'll let you know.
Message 13 of 14
(875 Views)
Hi RavensFan,
Thank you for the update. Yes, please keep us updated if this issue appears again.
Best Regards,
Kristi Martinez
Message 14 of 14
(860 Views)
