Feedback on NI Community
Cursor set to subject line instead of body when creating a message?
it seems to me there is a slight/subtle change whenever you start to create an answer: the cursor will be set to the start of the subject line instead of the "Body" editor.
This happens to me in the last days/weeks: sometimes I start to type into the "Body" editor window before the website is completely loaded. Once the website is completely loaded the cursor jumps into the Subject line: quite annoying as you have to correct the subject line later on and grab the mouse to click once more into the "Body" editor box…
It also seem to happen to other people (like Bob, message #2) as you can see by the subject lines in this thread
My request: is it possible to set the "Body" editor box as active input (aka "Key focus" in LabVIEW terms) when the website has finished loading?
(5,194 Views)
Just tried here and I see the same thing. I agree that this is not correct behavior.
(5,152 Views)
Yes. Same here.  I didn't realize at the time.  I thought I did something like click on the screen when my message starting showing up ahead of subject of the message I was replying to.
How is it that little dumb things like this happen to get introduced when the web programmer must have been changing something else?  And what were they changing?
(5,118 Views)
Hi GerdW,
Thank you for bringing this to our attention. We are working to identify the cause of this issue and will escalate it accordingly.
Best Regards,
Kristi Martinez
NI Community Support
(5,096 Views)
an update to this issue:
Now the cursor is frequently set into the "Tag" input field instead of the "Message title".
So the output is different, but it's annoying in the same way!
(4,959 Views)
Still the same problem of setting the cursor to the "Tag" input instead of the "message" after loading the message editor website:
This is how it looks like when the website is completely loaded. (In the image I wanted to edit my own message.)
It is quite annoying when you start typing before the website is finished with loading: the cursor jumps from message editor field to the "Tag" field!
(4,828 Views)
HI @GerdW ,
That is odd. I've opened a ticket for us to look at it.
Thank you,
Mark
Product Manager
Customer Learning, Community, Online Documentation, and Support
(4,817 Views)
