Feedback on NI Community
Discrepancy on time display.
Hello:
I am from the Philippines. I set my timezone offset to GMT+8 at personal preferences. It seems that the time displayed under "Latest Post" is advanced by 1 hour as compared to the local time here. Please advice. Is it I the only one who is experiencing a discrepancy on the time?
(4,609 Views)
Hello:
I think somebody tried to fix this problem. Unfortunately, it's on the wrong direction. Now it is advanced by 2 hours.
(4,563 Views)
Debonair -
I have experimented with the time zone settings and haven't been able to reproduce what you are seeing. I am suspicious of the Daylight Savings option being the cause of why it went from being one hour off to being two hours off for you.
I am posting this messages at 11:15AM CST (GMT -6). If my calculations are correct, it should show up as 11:15AM + 6 + 8 = 1:15PM for you if you are GMT +8. Is that right?
Thanks!
Molly K.
Web Support & Operations Manager
(4,536 Views)
Hello Molly:
There is an option on my profile that sets the automatic adjust of daylight savings time. I leave it unchecked.
Your message shows at 04-16-05 02:14 AM.
I am posting this on 04-20-05 8:55 AM.
(4,517 Views)
Debonair -
When I check the daylight savings option, the timestamp on the message I posted appears correctly. However, it doesn't match the timestamp that you mentioned you post should be displayed as. Do you see the same behavior?
Thanks!
Molly K.
(4,496 Views)
Hello Molly:
Yes. I believe you understand what I meant.
(4,481 Views)
