Feedback on NI Community
Discussion forums "Access Denied"
When I tried to access the following url as a logged in user
http://decibel.ni.com/content/blogs/quadrotor
Am I missing something
(4,545 Views)
That's what I see as well, how did you get to that page?
(4,538 Views)
I tried to look for some pointers to build a quadcopter using LabVIEW and came across this blog at
https://labviewrobotics.wordpress.com/2009/10/06/how-to-build-a-quad-rotor-uav/
which has a link to the ni forum
There's more
I also tried to read the "author's blog" from this url
http://www.ni.com/newsletter/51012/en/
I get the "Access Denied" in both the cases
Thank You for the quick reply
G S Reddy
(4,533 Views)
Hmm... that article is from 2011, and I know the forums have changed quite a bit since then. I think that page probably isn't "up" anymore because if I look through the blogs I don't see anything hinting at Ben Black's blog.
If you just type "quadcopter" into the top-level community page you will find about 54 results though, which may be useful.
(4,530 Views)
It is possible, it's an old post, I will browse through other community pages, or maybe try to tinker around LabVIEW and build it myself.
Thank You for pointing out
G S Reddy
(4,518 Views)
