Feedback on NI Community
Documents - Questions and Feedback
@LiliMcDonald wrote:
X. - I edited my post above to clarify on some of the points you raised.
As for the Community Hub, that particular group existed as a way to provide help documents or to ask questions on using the NI User Group Community. As the NI User Group Community no longer exists, the content within no longer needs to be publicly accessible.
Reading the title of the incriminated bookmarks, I now understand what you mean: these were typically posts about how the previous site worked (or didn't). A bit like the "Feedback on NI Community" forum this thread belongs to.
Message 31 of 54
(2,611 Views)
Hi RobertoBozzolo,
I believe Lili provided you a copy of the document via private message. Thanks!
Message 32 of 54
(2,608 Views)
https://decibel.ni.com/content/docs/DOC-48417 is another document of mine which has gone AWOL (from this post).
Message 33 of 54
(2,589 Views)
An example of dead links on NI's website: How Do I Access the Attribute Nodes of the Individual Elements of a Cluster?
The two links at the bottom of the page are dead.
I have used the form at the bottom of the page to inform NI of this, but this is a black box with no kind of acknowledgment that this did anything or will be followed with any sort of action.
It is clearly old, and now saved in the Wayback Engine.
Message 34 of 54
(2,586 Views)
If I create a new test document can you delete it after?  Getting everything formatted took a fair bit of time and I don't want to redo it repeatedly.
Message 35 of 54
(2,571 Views)
Tilee ha scritto:
Hi RobertoBozzolo,
Correct! Thank you all Smiley Happy
Message 36 of 54
(2,555 Views)
Is there an official channel to recover vanished documents?
Message 37 of 54
(2,545 Views)
Hi KitKate,
Do you mind explaining what you mean? Are you looking to use the test document as a template for formatting? We can delete documents if you'll notify one of us (the Community admins) when you need it done.
Message 38 of 54
(2,544 Views)
I found 2 published personal documents for you which I will send you via private message.
As these aren't community hosted documents, it is best to use the feedback form or contact form found on the page.
Message 39 of 54
(2,512 Views)
I am now able to submit documents for review.  Not sure why it didn't work previously.
Message 40 of 54
(2,504 Views)
