Feedback on NI Community
Formatting problems in LabVIEW forum…
today I see some strange formatting of the LabVIEW forum:
Notice the white background under the forum threads titles: the actual text is wider than the white background. Using FF49.0.1, the screenshot was taken with a 1300 pixel wide window. When I make the window wider than 1720 pixels the background fits well (or: as expected) to the thread display. When I make the window more narrow the problem stays , no matter how your "responsive" design tries to fit to the browser window. (Reloading the website didn't help either.)
(3,539 Views)
Hi Gerd,
Have you continued to see this issue? I am not able to get the same results using and the same browser version.
Do you have any idea when this issue first appeared? (We have not made recent changes.)
Do you see the same issue on other boards (LabWindows/CVI, NI TestStand for example)?
Please let me know if you have more info - hopefully we can get to the bottom of what is causing this! As your window width is reduce, you should see the column widths reduce, ultimately lock at a fixed width, and then "break" to become a single stacked column.
Thanks!
Matt
NI Community Team
(3,526 Views)
Hi Matt,
now the issue is gone…
I saw it this morning (CEST). Reloading the website and even restarting the browser didn't help.
Somewhen in the morning the issue has been solved/disappeared.
(3,521 Views)
Thanks for follow up!
I'm glad to here that the issue did not persist. It's strange that you saw this issue - as far as I know there was no ni.com or Discussion Forums maintenance during that time.
Please let us know if this returns or similar issues pop up in the future!
Matt
NI Community Team
(3,517 Views)
See here and the few posts preceding it.  I'd be willing to wager it's because of the long username.
Tim Elsey
Certified LabVIEW Architect
(3,515 Views)
