Feedback on NI Community
Graphic Date & Time in XY Graph
Hi, I need your help. I trying to graphic this info (below) in a XY Graph.vi but I can't graphic de date time Column in the X Axis
    X Axis                          Y Axis
2008-02-11  4:45:00    0   10   20   30
2008-02-11  4:46:00    0   10   20   30
2008-02-11  4:47:00    0   10   20   30
2008-02-11  4:48:00    0   10   20   30
2008-02-11  4:49:00    0   10   20   30
2008-02-11  4:50:00    0   10   20   30
For a better reference see the Attached Excel file "XY Graph Example.xls"
I need to do the same graphic inside excel file but in LabVIEW.
Im, using LabVIEW 7.1
(8,466 Views)
If you search the example finder (Help>>Find Examples), you can find examples which show how to do multiple plots in XY graphs.
For converting the string to a timestamp, you can use the VI attached here.
For reading the file, you can either look at the Excel examples or save the file as a CSV file and then read it using the LabVIEW file functions.
___________________
Try to take over the world!
(8,464 Views)
Thank for your help. This is the source code to graphicate date and time in a X Axis.
The VIs are in 7.10 version to make it compatible with  more LabVIEW versions.
Regards.
(8,441 Views)
Hello
I'm not understand please insert its VI example file.
Regards
(6,960 Views)
@hyghaderi wrote:
Hello
Regards
Please note that this post was created in the wrong forum. If you have a specific question (it's not clear from your post what you are asking), please post your question in the appropriate forum.
Is this a LabVIEW question? If so, post in the LabVIEW forum: http://forums.ni.com/t5/LabVIEW/bd-p/170
Is this a LabWindows question? If so, post in the LabWindows forum: http://forums.ni.com/t5/LabWindows-CVI/bd-p/180
Is this a Measurement Studio question?
   for C: http://forums.ni.com/t5/Measurement-Studio-for-VC/bd-p/231
   for VB: http://forums.ni.com/t5/Measurement-Studio-for-VB6/bd-p/230
   for .NET: http://forums.ni.com/t5/Measurement-Studio-for-NET/bd-p/232
(6,933 Views)
