Feedback on NI Community
How do I continiously measure amplitude
Hiii...
I am taking analog input using Traditional NI-DAQ Channel not DAQmx...using LABVIEW 7 EXPRESS
In the EDM fedback module I am designing, I must measure the amplitude of the incoming input voltage at specified time interval convert it to DBL type and pass this DBL value through another block diagram.
I am currently using "Acquire Waveform.vi" at 1000 sample and 1000sample/sec... after that I use "Get Waveform components.vi"...
The problem is...
I get an array of 1000 values after 1 second and I use "index array" after that to take individual values... This process is taking too long and I want to make this process instantaneous...
like.. I get 1 value and I can use it immidiately for further analysis..
here..I have to wait for 1 second before I can use it...
What do I do???
(6,184 Views)
Try posting in the appropiate forum first.
Regards
Ray Farmer
Regards
Ray Farmer
(6,182 Views)
