Feedback on NI Community
How to rate someone
   I was wondering about how to rate someone?
Waleed El-Badry MSc.,MCPD, ISTQB Certified Tester
Assistant Lecturer
Mechatronics Department
Faculty of Engineering
Misr University for Science & Technology
View Waleed El-Badry's profile on LinkedIn
(8,624 Views)
You should have a minimum of 50 posts posted in forum to rate somebody. I think today only you are crossing 50. So now you can see at the bottom right corner of every posts (rate this message). Click and rate.
Toss 5 if you feel it helped.
Else just leave. since other than 5 stars anything else will affect the designation of that person.
Hope it helps!
Mathan
(8,622 Views)
And now that you are above that threshold, you shld be able to rate, Right?You can check by tossing me a 5.Smiley Very Happy
(8,611 Views)
thanks guys. I do appreciate your help
Assistant Lecturer
(8,605 Views)
Is this option gone? I have over 50 posts and am logged in but do not see it giving me the option of rating a message anywhere.
(8,116 Views)
The rating system is gone. Kudos are used now. If you like the answer, just click on the orange Kudos icon.
(8,111 Views)
Yes, I know about Kudos, I just couldn't find anythign specifically saying the rating system was gone or had been replaces so I wasn't 100% sure. Thanks.
(8,109 Views)
