05-22-2005 05:40 AM
05-22-2005 08:50 AM
05-22-2005 09:12 AM
05-22-2005 09:50 AM
05-22-2005 10:09 AM
This is definitely a weakness of this forum : While discussing about the ease of graphical programming, we are obliged to rely on text-based functions ! 😛
Ben wrote:...I really wish this was automated. HTML should not be required part of of vocabulary...
05-22-2005 11:48 AM
I used some freeware mpeg to AVI converter, then took the AVI it into corel photopaint where I appled the following functions:
@chilly charly wrote:
What tool did you use ?
05-22-2005 12:42 PM
@altenbach wrote:I used some freeware mpeg to AVI converter, then took the AVI it into corel photopaint where I appled the following functions:
What tool did you use ?crop to 144x144 square area, then resampled to 25% size giving 36x36 sized frames. select a series of about 64 frame, then dropping every odd frame and halving the frame rate, leaving 32 frames. convert the original 24bit color to an optimized palette with only 16 colors (Since there are only a few shades of blue and grey it still looks pretty good. It gets blocky with 8 colors). save as an animated GIF.
05-22-2005 01:05 PM
@tst wrote:
Unfortunately, the satisfaction of seeing that frog run over wasn't enough to compensate for the feelings brought on by seeing it again. BTW, is that the train from Ray's avatar?
I must say that I think this frog is definitely a good speaker against the proliferation of 3D software.
If you want a frog (toad, actually) movie which speaks for it, try looking at What happened to Baz...
05-22-2005 03:32 PM - edited 05-22-2005 03:32 PM
Message Edited by Ray Farmer on 05-22-2005 09:35 PM
05-26-2005 05:09 AM
