Feedback on NI Community
Inquiring about the issue of using PCI-5922 and PCI-5412 simultaneously under Linux OS! Thank you!
hi all,I am lily and I an AE from NI shanghai .Now I confronted a pullze from customer,and I really feel at a loss! Hope some one of you would come and land me a hand,thank you in advance!
The problem is as follows:
Customer use PCI-5922 and PCI -5412 under Linux OS, if they use either of the two cards seperately,there would be OK. but if the use both of the two cards simultaneously, the error will occured as attachment shows. "Error code:-50258 occured at niscope_DAQmx Create Channel (AI-Voltage-Base).vi:2  Possible reason(s):The specified software component failed to initialize."
Can I know is there any solution vs this probelm?Thank you in advance!!
(5,938 Views)
This is the wrong board for this question, you should re-post here
Regards
Ray Farmer
(5,932 Views)
