Feedback on NI Community
LabVIEW Openings
In Job openings board, most of the people are sharing their profiles without checking actual postdate and also Authors comments.
Sometimes Authors are saying, requirement is done, but some people are sharing their resumes. Sometimes people are sharing their profiles to 2 or 3 years old posts.
What about this idea?
Once recruitment is done, we need to disable "Reply" button to that thread.
Munna
Message 1 of 14
(8,593 Views)
I'm fairly confident that those notorious posters are eager enough that they will oversee any indication provided that an opportunity has passed.
I judge the success rate of this idea to be a lot closer to 0% than 100%.
Message 2 of 14
(8,589 Views)
I just requested that a moderator remove two of the old and closed openings.
-AK2DM
Message 3 of 14
(8,564 Views)
Hi Munna,
Thanks for the idea. I raised this enhancement to our platform vendor Lithium as there is currently nothing like this out of the box.  Also, we are discussing internally how to best address this problem now.
Message 4 of 14
(8,538 Views)
Lili,
First, Welcome to the Forums.  You have accomplished quite a bit in your short time on the job.
I notice that many old job postings have been removed. Thanks. It was a bit of a shock at first because I scan the New column to see whether I need to look at a particular Board.  I remember the number of unread posts and if the value has changed, then I look at the Board to see what has been added. Please understand that this is not a complaint or a request to go back to the old way, just an explanation of how one strange user monitors the Forums!  When the New value went from ~2440 to 133 it took me a moment to recall this thread as the reason.
Lynn
Message 5 of 14
(8,496 Views)
@johnsold wrote:
Lili,
Lynn
Hi Lynn,
Nice catch! Cat Tongue To prevent old job opening topics from resurfacing, all topics older than 3 months were moved to a read-only archive here. The announcement section at the top of the Job Openings board has been updated to include a note on this new process and a link to the new archive.
Also, thanks for the welcome! Cat Happy
Message 6 of 14
(8,491 Views)
@LiliMcDonald wrote:
@johnsold wrote:
Lili,
Lynn
Hi Lynn,
I almost hate to say it but,  Perhaps those jobs boards should be migrated to the Community side.  (With ample announcements)  Job availablity threads replaced by job availability announcements defaulted to 3 mo expirations (adjustable by the announcer)  Simillar announcements of developer availabilty that can be brought down by the developer when the availability period no longer exists.
There are current groups over there already (Even linked on the special interest boards) AT WORST some highly unqualified candidates, those who can't follow simple instructions, will be presented with entry barriers.  I can't really imagine a HR department that wouldn't mind that little extra screening.    The Jobs boards have probably earned their pensions and deserve a fair retirement.
Message 7 of 14
(8,465 Views)
Hi Jeff,
Thanks for the suggestion. We'll keep this in mind as we consider the long term strategy for the job posts and resumes.
I also wanted to mention that the LabVIEW Developers Seeking Employment board has gone through a similar archiving process. Going forward, resumes will be archived after 1 year and made available in a read-only archive.
Message 8 of 14
(8,432 Views)
LiliMcDonald wrote:  To prevent old job opening topics from resurfacing, all topics older than 3 months were moved to a read-only archive here. The announcement section at the top of the Job Openings board has been updated to include a note on this new process and a link to the new archive.
It would be nice if something similar happened with the Version Conversion Board.  Of course, I would still really like something like this as well.
GCentral
Message 9 of 14
(8,383 Views)
Good suggestion. All topics older than one month from the Version Conversion board have been moved to a private archive. We'll continue to archive topics from that board on a monthly basis.
Message 10 of 14
(8,352 Views)
