Feedback on NI Community
LabVIEW driver for watlow'96
Hello
I need to set and read temperature to/from Watlow '96 using LabVIEW. From this discussion forums I found library files called Watlow96.llb written and posted by Brian Vibert (Thanks Brian). I tried to run it using RS232-RS485 converter. However, I got the following error: Serial port timeout; bytes not received at serial port.
My settings are Baud rate: 9600, timeout: 10sec, data bits: 8, parity: None and flow control: none.
Can any one help me sorting out this matter.
Thank you for your help.
Nur
(4,662 Views)
Dear Nur,
Please post your question in the Serial Interfaces forum.
Monica Warren
(4,662 Views)
