Feedback on NI Community
Messages not getting marked as read.
Just noticed this about 9:10 am EDT.
A couple of message threads that have new messages, I went into and read them.  When I was back at the forum page and refreshed the screen, those threads still showed as having unread messages.  I'm logged in the entire time.
It seems that the forum stopped marking the messages I just read as having been read.
Message 1 of 13
(5,043 Views)
As an update, I'd figured I would log out and log back in.
Still the messages aren't getting marked as read.
I noticed it is happening in the LabVIEW forum.  The feedback forum doesn't seem to have the problem.
This message https://forums.ni.com/t5/LabVIEW/Text-file-is-keept-in-memory-and-not-deleted/td-p/3685554/jump-to/f... and the ones with more recent replies.
It seems to be the ones listed on the board above the CLAD related question that I moved to the certification board.  The 3 marked in red in the attached image.  The ones below the moved message I can read and have the messages marked as having been read.
Message 2 of 13
(5,041 Views)
Now it seems to have cleared itself up and the messages I had read earlier are now being marked as read.
Message 3 of 13
(5,025 Views)
Accepted by topic author RavensFan
Thanks for reporting this. I am seeing the same issue in the LabVIEW board. We will continue to investigate this.
Lili
Message 4 of 13
(5,019 Views)
I see this happening again today for any threads I've read after I had merged a message into this thread.
https://forums.ni.com/t5/LabVIEW/Subvi-as-Consumer/m-p/3697616#M1039838
Message 5 of 13
(4,866 Views)
Thanks for the example. We have passed this along to our community provider for further investigation.
Message 6 of 13
(4,860 Views)
Now, after waiting about 15-20 minutes, those threads are finally showing up as read.
Message 7 of 13
(4,859 Views)
I just did a quick test of this and I am seeing the topics marked as read immediately after reading then going back to the LabVIEW board (via the breadcrumbs, not the back button). Are you still seeing this issue as of today?
Message 8 of 13
(4,634 Views)
I have not been seeing it today.  It seems to come and go.  At least two distinct times after I had just done a merge thread.  I believe there are other times where I have merged threads since and have not seen it.  I haven't been as active on the boards today so I can't confirm it still wouldn't happen.  The repeatability of the problem seems hit or miss.  I'll let you know if I see it again.
PS:  Why does the dictionary not consider the word "repeatability" valid?  I just added it to the dictionary to get rid of the red squiggly lines.
Message 9 of 13
(4,628 Views)
same problem here:
- I'm logged in.
- I wrote the last message in the "polymorphic subVI …" thread.
- I opened the thread two times to "really read!" it…
Yet it still is marked as unread - with a new message (yes, it's my own message!)…
Message 10 of 13
(4,610 Views)
