Feedback on NI Community
Multiple post mystery
I've just caught myself sending multiple posts.
I'm not sure exactly which sequence of keys I hit, but when I pressed the spacebar, I noticed the screen flashing and stopped typinf.  Fortunately, only two made it and I cancelled the third one.
I may have hit the Ctrl button instead of Shift.  However, the strange part was that it would send a reply each time the spacebar was pressed...
I wonder if something similar causes the multiple posts that we see which contain one extra word in each of the submitted thread..
R
Message 1 of 24
(8,008 Views)
I agree that there are sometimes fragmented "serial posts" that can only be explained by some malfunction like this.
What browser are you using? What kind of browser toolbars are installed?
It could just be some corruption in memory. Did you try to completely close all browser windows and start over? (or even reboot the computer).
I would also do a virus and malware/spyware scan.
Message 2 of 24
(8,003 Views)
I'm using IE 6.0.2900, with no special toolbar installed.
I don't think it was corruption in memory.
There was no need to completely close all browser windows and start over.
I am sure I hit some odd combination of keys.  The surprising part was that the keyboard would submit the post..  And a continue with a new one.  It's the first time I had this happen.  I'll try to reproduce it.
I regularly do a virus scan, and had restored the PC about 1 month ago. So it should be "relatively" clean.
R
Message 3 of 24
(7,993 Views)
This is a known issue in Internet Explorer on the forums.  I'm not sure quite what happens, but I've always thought it was through the use of the tab key which gets you into this weird state.
I am always happy to clean up multiple posts, so just notify me.
Thanks!
Laura
Web Support & Operations
Message 4 of 24
(7,965 Views)
I tried to reproduce the multiple posts, but did not try the Tab key.  Actually, I have had the Tab key issue in the past.  It posts prematurely...  However, when this occurred, it was different, it would post and open a new window with all the text that was typed so far and it would post it as soon as I hit the spacebar.  Fortunately, I was looking at the screen when it happened and only two posts made it..  I stopped typing beforing hitting the spacebar a 3rd time.
At least, in my case, it was a multiple post within the same thread..  Nothing bad... Just helped my post count 😉
R
Message 5 of 24
(7,962 Views)
Tab key gets you out of the edit box and highlights the submit button?  Pressing spacebar on a highlighted button is like clicking on it?  Still doesn't explain how the edit box would retain focus for accepting keystrokes or that once it is submitted, the edit box still has all that was typed up to that point.
EDIT.  I just did a tab key.  Yes the Submit button highlighted.  Did a spacebar.  Yes it submitted it.  But it did not return back to the message, it just behaved like I had submitted normally, i.e. showing me my posted message.
Message Edited by Ravens Fan on 07-07-2008 01:25 PM
Message 6 of 24
(7,957 Views)
Hi Ravens Fan,
Yes, I've seen what you described before..
But this was different... It retained what I typed..  Each post contained an additional word.  I will illustrate below (in the next posts).
So that was "strange"... and it may help understand some multiple posts where there is a new word in each of the posts...
Here we go with an example...
Message 7 of 24
(7,952 Views)
This
Message 8 of 24
(7,952 Views)
This is
Message 9 of 24
(7,951 Views)
This is an
Message 10 of 24
(7,950 Views)
