Feedback on NI Community
My DAQ application requires no mechanical parts. OS must be small to fit in flashdisk. Need advice
My DAQ application must operate in very low and high temperature conditions and must have no moving parts. Need advice on products and venders names that I can use. The application requires collecting data simultaneously from 32 sensors and stores them temporarily on flash disk and later sends the data to a host system for post processing.
(4,368 Views)
Hello;
To be more accurate on my suggestions, I would need to know how fast the acquisition will run.
If the speed is not a concern, you can take a look at our Field Point modules, that are designed for industrial plant floors, and can handle a pretty wide temperature range. Also, you can look at the Field Point 2000 that is a stand alone controller that can be used together with the DAQ modules.
If speed is a concern, I would recomend you to take a look at the PXI modules.
Hope this helps.
Filipe
(4,368 Views)
