Feedback on NI Community
New Login Page/Authentication Method
After clearing the cache and the cookies, I saw it once, but not since then. I will keep using it and see if it comes back.
Also, I will say that when it did happen, I was logged out of the forums, but not out of ni.com (meaning I did see the Hello XXX, this is not me link)
___________________
Try to take over the world!
Message 11 of 60
(4,699 Views)
I'm having a weird issue where I try to sign into the Communities site and then it asks to confirm the account.  But I never get the email to confirm the account.  It isn't in the junk folder.  I can't do anything with the communities except browse as a guest.
I logged out of everything and even cleared the cache.  Signed into the communities site and left it at the confirmation page.  Using another tab, go to the forums and it signs me right in.
Windows 7 64-bit, Firefox 19
Message 12 of 60
(4,692 Views)
Thanks for testing it out. Hopefull that'll resolve the issue. I still have yet to be logged out of the forums. Also, it's worth mentioning that the idle time is set to 90 min at the moment - meaning if you're idle in the forums for more than 90 min you will be automatically logged out and will need to click the login link. Your cookie info should still be stored, so you shouldn't have to re-login, just click the link. Had you been idle for more than 90 min when seeing the behavior earlier?
Jordan
Message 13 of 60
(4,689 Views)
Hi crossrulz,
I'm going to mention Hassan in this post as he is the point of contact for this validation. He might be able to add to my explanation.
I experienced something similar. If you have a new account you should get the email automatically. If you have an existing account (like you and I do) you will need to select the "Send new confirmation email" button. This confirmation only affects the Community at this moment. You are not required to validate your Forums account as of right now. You should only have to validate your profile one time, so if we validate Forums accounts in the future you should not have to go through this process again.
Hope that helps.
Jordan
Message 14 of 60
(4,686 Views)
No, it was more on the order of 10 seconds to a minute. Basically, it was log in (successfully), click a link and you're logged out.
___________________
Message 15 of 60
(4,674 Views)
Hi crossrulz,
Hope that helps.
Jordan
I did click that button.  But still no email.
Message 16 of 60
(4,670 Views)
Hi Crossrulz,
I apologize for the confusion.  For current community members there are two buttons that must be clicked:
You first need to click this button here:
step1
That should then bring up this window, where you will need to click the button below that should actually send the E-mail:
Hassan Atassi
Director, ni.com
Message 17 of 60
(4,658 Views)
I could have sworn I tried that already.  I just did it all again with IE this time and it worked like a charm.
Message 18 of 60
(4,646 Views)
Jordan, now it's back to not working well, both on that PC and on another one (FF 18, Win 7), so I'm going back to the old link. Tell me if you need me to go back to the new one.
___________________
Message 19 of 60
(4,629 Views)
I am having exactly the same problem. I never get a validation email. I even created a new account and it validated correctly. This is getting frustrating as I need to access a private group and am unable to do so until I can validate.
David C
Message 20 of 60
(4,616 Views)
