Feedback on NI Community
Path to LabVIEW help files
OOOPS!
Wrong board!
Excuse me, will try at a more appropriate board.
I'm working in an environment where ClearCase is used as version control system. We have also put the LabVIEW folder under ClearCase control to get the same environment for everyone working in the project. However, one litlle problem arises with this for us. LabVIEW can no longer access the help files. "Whenever "Click here for more help" is used, the html help browser opens, and is directed to the right location in the tree, but the help window is blank.
I have some suspicion that this might be due to some security settings decided by the company, but I haven't found any way around it. My idea now is to try and point out the help files to the hard drive, and I was hoping that there might be an entry in the LabVIEW.ini file I could make to separately point out where the help files recide.
So my question:
Is there such an entry to make in the ini file, or is there any other way to get around my problem.
Regards
//Martin
Message Edited by M_Peeker on 08-10-2005 07:21 AM
CLA
https://www.prevas.se/expertis/test--regulatoriska-krav.html
Message 1 of 1
(4,292 Views)
