Feedback on NI Community
Post editing problems
I have opened a case about this bug with Lithium. I will report back when I have an update.
Message 11 of 21
(3,590 Views)
Thanks, Lili
Cheers
Message 12 of 21
(3,584 Views)
LiliMcDonald wrote:
Neither of you are seeing this issue in Firefox, correct?
I still have not seen this issue with Firefox.
Message 13 of 21
(3,553 Views)
Lithium is still investigating the issue, but they would like to know if the following changes anything:
1. Log out of the forums
2. Clear your browser cache/cookies
3. Close the browser
4. Reopen the browser and log in to the forums
5. Attempt to edit a post
If someone experiencing the editing issue could please try the above and report back, I'd appreciate it.
Thank you!
Message 14 of 21
(3,537 Views)
Apparently I haven't been active enough this morning, so all my posts are too old to edit. Smiley Happy
I'll try it out on this post.
Cheers
Message 15 of 21
(3,528 Views)
Well, I can edit the above post now right away. I had to do the HTML switch trick before I performed the steps, so success? I'll let you know if I see the problem again elsewhere.
Edit: Nope, I edited this post and had to do the HTML trick.
Edit2: My above post requires the HTML trick now as well...
Cheers
Message 16 of 21
(3,519 Views)
Hi James,
I see your edits stating you're still encountering the issue. I assume that's still the case?
Message 17 of 21
(3,477 Views)
Yup, unfortunately so.
Cheers
Message 18 of 21
(3,474 Views)
Thanks for confirming, James. Lithium has reproduced this bug on their end and are working with their development team to address the issue. I'll post back when there's an update.
Message 19 of 21
(3,458 Views)
I have received confirmation from Lithium that this issue has been fixed. Please let us know if you have any more issues.
Message 20 of 21
(3,399 Views)
