Feedback on NI Community
Problem with Firefox
nathand -
Can you load this URL?
http://ni.i.lithium.com/skins/HEAD/32B709F80C716E1DFF4FFA721BEF1E7E/ni-1991929918.css
Can you try clearing your cache and then going back to the forums?
We can't reproduce the issue and it seems to be affecting only a small number of users, which makes troubleshooting difficult.  I've reported the issue and we're trying to get additional information from the users that are experiencing it.
Laura
Message 11 of 14
(4,707 Views)
I get a completely blank page when I load that link in Firefox, even if I go to "View Source."  When I view it in IE, it loads a blank file into Notepad.  Oddly I can access that link properly through Lynx running on a unix shell elsewhere.  If I go to the forums within IE and View Source, I can see that it's loading a different stylesheet, which does load in Firefox.  I checked that it's not an ad-blocking issue in my Firefox configuration, since that has occasionally caused problems in the past.  Clearing the Firefox cache has no effect.
Message 12 of 14
(4,705 Views)
GregS' fix worked for me, even after later removing the config string.  Oddly, I think this fixed the problem for me on my home computer at the same time (although I can't prove that).  Is it possible that the problem is somehow related to a property saved in a specific user's profile?
Message 13 of 14
(4,671 Views)
That's odd - I'm not sure how or why they would be related.  I'll pass along the information.
Laura
Message 14 of 14
(4,649 Views)
