Feedback on NI Community
Problem with sorting a search
I'm using Win7 and IE9.
I did a search of the forums based some keywords.  The default sort order is Best Match.  I wanted to sort on date.  I clicked on the "Best Match" dropdown to the upper right of the list.  I got a drop down for Date, Kudoes, View, Replies, etc.  It looked like they would have sub drop downs probably like Oldest First, Newest First.
So I clicked on Date.  The dropdown disappeared and it went back to Best Match.  No matter which other sort I tried, it just went back to Best Match.  Hovering over any of the choices didn't help either.
So my problem is that I can reorder the result list when I do a search on the forums.  This happened in multiple message boards.
(5,587 Views)
I do not see the problem on Safari on the Mac. Although as you pointed out no subsearches seem to be possible.
My somewhat sarcastic thought when I read your post was that since the search works so poorly, they probably put little effort into sort.
Lynn
(5,575 Views)
Sorting by date or other things used to work.  But I don't remember how long ago I last tried to do it successfully.
One other thing I noticed was that when I tried to do an advanced search when I tried to only search for posts written by me, or within the past month using the filters on the left hand side, I still seemed to get a full list of messages and they weren't filtered.  So I had a long list since it was unfiltered, and no way to sort it by date.  I eventually found the message I was looking for, but not by way of the search function.
Web team, please look into this.
Anyone else, please try sorting and/or filtering yourself.  Particularly if you are using IE9 or another IE version and comment on it.
(5,567 Views)
