Feedback on NI Community
Problems giving KUDOS with Firefox 3.0.3 but no problem with IE 6. :-(
Somehow my Firefox settings disable the function of giving Kudos 😞    however it works with IE, but ...
All coffee (Java) enabled for ni.com, still no chance :-((
Is it possible to add a 'Give KUDOS' entry in the article options ?
Greetings from Germany
Henrik
LV since v3.1
Message 1 of 11
(14,090 Views)
I also run FF 3.0.3 and have had no problems giving Kudos. There's no Java on the forums, just Javascript (different beast). I'm guessing an extension/add-on is interfering. Try running FF with all add-ons turned off.
Message 2 of 11
(14,079 Views)
no ADD-On, plaint FF, no change 😞
But I remember a security fix that involved a about:config change....
Sorry not able to give a KUDOS ...
Message Edited by Henrik Volkers on 10-24-2008 03:15 PM
Henrik
LV since v3.1
Message 3 of 11
(14,045 Views)
I don't recall such a fix, and I just checked before I wrote this reply that I am up to date with Firefox, and am able to give Kudos. Perhaps someone else running FF3 can try to replicate the situation?
Message 4 of 11
(14,035 Views)
I've had problems giving kudos as well in Firefox 3.03
I am able to in FF2 and IE
I've turned off all the add-ons but to no effect 😞
_____________________________
- Cheers, Ed
Message 5 of 11
(14,027 Views)
I have no problems giving Kudos with FF3.0.3 German.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 6 of 11
(14,023 Views)
I have not upgraded yet so I can't try to reproduce.  I did submit the issue to Lithium to see if they have heard about this issue previously.
Laura
Message 7 of 11
(13,971 Views)
Has anyone with this problem disabled the "Enable Live Updates" option in their preferences?  I wonder if this would help at all...
Laura
Message 8 of 11
(13,883 Views)
Laura, can you kindly tell me whether this part "Live updates" has been removed from the preferences section?
Message 9 of 11
(11,308 Views)
Yes, it appears to not exist any longer.  You can choose to disable Kudos in Preferences - Kudos and tagging on the Tagging tab of My Settings.  Did you have live updates disabled?
Laura
Message 10 of 11
(11,289 Views)
