Feedback on NI Community
Request Entity Too Large
Over the last few days I've been sporadically getting this error message (with the URL inside changing depending on what I'm doing):
The requested resource
/t5/LabVIEW/measure-time-lapsed-from-reaching-threshold-to-execution/td-p/3839140/page/3
does not allow request data with GET requests, or the amount of data provided in the request exceeds the capacity limit.
Sometimes it persists if I try to reload the page or navigate back and forward again, sometimes it goes away and the page loads properly. Any ideas?
Message 1 of 14
(4,268 Views)
Hi arteitle,
We are aware of the issue and our team is investigating it. The workaround for this issue if you should run into it again is to clear your browser cache/cookies.
Best Regards,
Kristi Martinez
NI Community Support
Message 2 of 14
(4,262 Views)
I cleared my ni.com cookies last week and that seemed to have fixed it, then I just went to mark this question solved and got:
/t5/forums/v4/forumtopicpage.markmessageasacceptedsolution/message-uid/3842779
D'oh!
Message 3 of 14
(4,229 Views)
Hi arteitle,
Our team has found the root cause and hope to implement it when priority allows.  In the meantime, please continue to use the workaround.
Best Regards,
Kristi Martinez
Message 4 of 14
(4,226 Views)
Have the same problem.
Someone used a wrong string length function?  It's unicode.
George Zou
Message 5 of 14
(4,100 Views)
I guess it's not fixed yet ....
Message 6 of 14
(4,094 Views)
The core issue causing this issue weeks ago was resolved on our end. If you're still encountering the error, it might be related to a new issue.
We recommend clearing your browser cache. If it happens again, please let us know.
Lili
Message 7 of 14
(4,065 Views)
I cleared all NI related browser cache yesterday.
I got 413 Request Entity Too Large again today.
/t5/NI-LabVIEW-CVI-数据采集等产品讨论区/请问各位-能否在labview的基础上-用坐标系实时显示小车的位置-拜托各位了/td-p/3866252
George Zou
Message 8 of 14
(4,050 Views)
Hi George,
Thanks for letting us know. We will investigate this further and let you know when we have an update.
Lili
Message 9 of 14
(4,041 Views)
Hi Lili, I have the same problem in Japan.
I feel that Japanese DF often causes the problem. On the other hand, I have never seen it in English DF.
Press F5 so many times or back to community top page will resolve but this is inconvenient : <
Certified LabVIEW Developer
GCentral
Message 10 of 14
(4,026 Views)
