Feedback on NI Community
Search function strange behaviour
If I enter a specific Forum Board (i.e. LabVIEW, LabWindows/CVI, ...) and I do a research clicking on the "GO" button, the first time this research is limited to the Board where I am, and I think this  is OK.
Then I can read the results, and suppose I realize I could use a different search expression to have better results. So I change the search phrase and I press GO again, but this time the search is performed in all the NI forum, and I don't like this.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(5,848 Views)
I think the behavior is reasonable. Expecting the server to remember where you came from before is a bit excessive. Also, it's possible that you're doing another search because the original search scope (which you didn't realize was there because it's silent) was too limited and didn't find what you want. Bottom line - if you want to set a specific scope, you can click the Advanced link next to the search box.
___________________
Try to take over the world!
(5,845 Views)
