Feedback on NI Community
Submit post does not work for me anymore ?
Hi Molly ,
Submit post does not work for me any more? I'm nost sure if this will be submitted!! I have been trying for an hour to do that?
Regards
Rajesh
(4,477 Views)
Rajesh -
Sorry to hear that you were having problems submitting your posts. Can you describe the behavior when it wasn't allowing you to post? Are you able to post now? If you are still unable to post, you can try the "Report Abuse to Moderator" option from the Options menu on the right of a message post to get in touch with me.
Thanks!
Molly K.
Web Support & Operations Manager
(4,463 Views)
Hi Molly ,
I tried reporting abuse to the moderator.But i get a message saying fields must be shorter than 25 characters in length.I do not understanf it. Any ways ,When i click submit post, the entire message body and attachment box goes blank.I was trying to attach a zip file ! Besides that i was trying to reply to an earlier thread.I even tried creating a new thread.But in Vain.The thread which I created is "Can i write data into an AVI file so that i can see it ?".Quick resolution of this issue would be greatly appreciated.My login id is smvrajesh@hotmail.com
Regards
Rajesh
(4,457 Views)
Rajesh -
I suspect that the problem that you were experiencing was caused by the size of the file you were trying to attach. Is there any way you can reduce the size of the file to less than 5MB?
Thanks!
Molly K.
(4,453 Views)
Attachments have to be less than 5 MB? That might explain a problem I was having posting an attachment earlier today.
(4,409 Views)
